roaming mexico
  • 21 October 2013
  • 1 reply
  • 529 views
taking 2 phones to mexico , do i have to change simcards
Best answer by Dennis 21 October 2013, 20:53
You have 2 options: 1) You could add the Int’l Dialing and LD Saver ($2/month) and International Voice Roaming ($0/month) so you could roam in Mexico at the roaming rate http://help.koodomobile.com/coverage-long-distance-and-travelling/Travelling 2) You could unlock your phones and get a local sim card to use while in Mexico This option is usually the least expensive. You can get your koodo phone unlocked for $50 as long as your account is in good standing for the past 3 months. Or you can try a 3rd party unlocker
1 reply
