Roaming?
I have a data plan with Koodo nada number for Edmonton. I am wondering if I travel within Canada will there be roaming charges? I won't call anyone but I will use the data.
Your data is available Canada wide with no additional charges.
But calls would be extra right?
There is no Roaming in Canada If your plans name starts with "Canada Wide" , that means you can call anywhere in Canada from anywhere in Canada without additional long distance charges. Check in self serve for your plan details.
Everything says nationwide for data wtc but calls just say airtime minutes...
Somewhere In the name of your plan should be the word "CAN" or "Canada" or "Canada wide"
It doesn't really say
Unlimited Canadian LD
The postpaid plans can all be used anywhere in Canada with no extra charges. I think some of the prepaid rates may be different outside your local area, but I'm not sure about that.
