Restrict use on a phone
Is there a way I can restrict the use on my daughter's phone from time to time?
Is it a smartphone? If so, go into the app store for that device and search 'parental control'. There are many parental control apps out there availble for download and free too
You can try these guys out. It's a canadian company from Toronto: https://www.kytephone.com/
Lmao, I knew someone would post that. But its only compatible with Android, or so it seems.
I think it's a bit overkill. OP asked for a way to restrict use, the app mentioned is more akin to full on spying...
