Hello,
I was with koodo, bought a phone then had it deactivated because i no longer needed it. I now need it...how do i go about having it reconnected to the network ?
Best answer by Sophia
You can use the phone with any plan. If you currently don’t have a plan, you can check Koodo’s website and either sign up for a BYOD plan (since you already have a phone), or you can sign up for prepaid… whatever you choose!
