Can someone tell me why I can get better reception on the bottom deck of a steel hulled ferry than I can anywhere in my house, especially as I can see a Telus cell phone tower just across the inlet where I live?
Best answer by nim4165
Check your Mobile network settings ‘Preferred network type’ and ‘experiment’ with different settings (Global / 4G/ 3G). Select and use the Type which provides you with the best reception (highest number of bars). Note that you may find that your best reception may be 3G, which improves your call quality but degrades your data rates.
