pixel 4a WiFi calling
  • 16 September 2020
  • 1 reply
  • 40 views
Got a pixel 4a from Google and tried to enable wifi calling but it didn't work. Koodo wifi calling page says newer pixel is supported. Wondering if it isn't available to the 4a yet or I did it wrong?
1 reply
Userlevel 4
It should work, since it’s on the list of devices that work for wi-fi calling. https://www.koodomobile.com/en/help/wifi-calling
I suggest you to click the link above and follow the instructions on the page. If it still doesn’t work, you should reset your network settings and try again.
