Phone Compability
  • 5 February 2021
  • 4 replies
  • 72 views
Is this phone compatible with KOODO:
The U.S. unlocked Palm supports the following bands:
  • 2G: GSM 850/900/1800/1900
  • 3G: UMTS 1/2/4/5
  • 4G: FDD 2/4/5/12/13/17/66
Best answer by MilkyWay 6 February 2021, 01:46
  • 3G: UMTS 1/2/4/5
Yes, the phone is compatible with Koodo. It should work on bands 2 and 5 for the 3G network and bands 2, 4, 5, 12, 13, and 17 for the 4G network.
  • 3G: UMTS 1/2/4/5
For future reference Koodo has a check your imei page to see if it should be compatible and you can also use willmyphonework. Net to see if just about any phone will work with just about any carrier in the world
2G is not used by Koodo.
Bands 2 & 5 are 3G, 4G
Band 4 LTE AWS-1
Bands 12, 13 & 17 (700 MHz LTE - rural use)
Band 66  AWS (used in the U.S.)
This phone should work on Koodo’s network.
thank you very much for the infos
