Personalized voicemail greeting for blocked numbers?
Is it possible to add a special/different personalized voicemail greeting for a blocked phone number (not sure if this helps but I have an LG G3 phone).
Not easily no. But I will look into it. Maybe an app will help.
Userlevel 4
Hi Melissa, it's definitely not possible with the standard voicemail options. All voice calls redirected to voicemail will receive the same greetings. Perhaps there is indeed apps able to redirect unknown callers to a different answering system, but it won't be with your same Koodo voicemail box.
