Nuu G 3 unlocked phone will it work with koodo
  • 20 June 2020
  • 85 views
I'm looking to buy a Nuu G3 unlocked. I want to make sure I can use Koodo prepaid with this phone. Does anyone know? I have not purchase the phone yet so I do not have a IEMI #
Could you post a link to where you’re buying it from or share the frequencies that the phone supports?
  • Android 8.0 (Oreo)
  • Rear Camera: Dual 13MP + 5MP, Selfie camera : 13MP
  • Helio P25 Octa Core 2.39GHz
  • 5.7” HD+ (18:9) 1440×720 Display
  • 3,000 mAh Battery – Express charging
  • STORAGE: 64 GB, RAM: 4GB
  • From walmart. I can get more info in a bit I just copied that from what was listed on the Walmart website
  • Thank you for the help
Is Koodo GMS
Network & Cellular
  • Network Technology
    GSM / UMTS, WCDMA / FDD-LTE, TD-LTE
  • 3G Support
    Yes
  • 4G Support
    Yes
  • 2G Network Bands
    GSM : 850 / 900 / 1900 / 1900 MHz
  • 3G Network Bands
    UMTS : 850 / 1900 / 2100 MHz
    UMTS : 1700 / 2100 MHz
  • 4G Network Bands
    LTE : 700 MHz Class 17
    LTE : 850 / 1900 / 2600 MHz
    LTE : 1700 / 2100 MHz
    LTE : 700 MHz (Band 12)
  • SIM Card Type
    Nano+Nano/microSD
  • Number of SIM Card
    Two
  • Dual SIM Support
    Yes with Hybrid Dual SIM support
Software & Platforms
  • Operating System (OS)
    Android 7.1 Nougat OS
  • User Interface (UI)
    Yes with Modified Androids
  • Does this help?
Based on those frequencies, yes, it should work.
Koodo uses 850/1900 for 3G service and 1700/2100 for 4G/LTE.
They do not have a 2G/GSM network.
