Now, I have been using MB number and $48plan
Now, I have been using MB number and $48plan. I will go to Alberta to take a school so i just want to change my number to Alberta number. But there is only MB provice I can change on Self Serve. How can I change my number to Alberta. Please let me know
Hi Eric,
If you change to an Alberta number you would have to change to an Albertan in-market plan. Since the plan you have is canada-wide, why not keep your current number with your plan?
Mathieu wrote:
Hi Eric,
If you change to an Alberta number you would have to change to an Albertan in-market pl...
I just want to change the number, is there any other way to change my number without changing the plan
Mathieu wrote:
Hi Eric,
No there is not.  SInce plans are typically canada wide, I recommend staying with your MB plan and number.  A similar plan in AB will cost your $90
