No Sound from phone
There is no volume on my phone-ring or text- the vibrate works but no sound? Any help, besides the obvious side buttons that say the volume is at max
If you own an Android device, drag your finger from the top of the screen downward (windowshade mode) and check to see that you haven't set your device to vibrate only. By tapping on the Sound icon you can change from vibrate to mute to sound. You want the sound setting. Or you can go into: Settings > Sound > Volumes and make volume adjustments there.
Hello Pat. If you're on an iPhone, just disable the silence switch on top right of the phone.
