Need to know what info is needed from work to save on bill
  • 10 November 2014
  • 4 replies
  • 7 views
I was told that I can save 25% on my bill because of my place of employment, but I'm not sure what I need to give Koodo in order to get that. Would anyone know?
Most often then not, your management team or human resources would have a contact person or group who would send that information on your behalf. Otherwise, calling *611 will get you to the experts who may know of the process specific to your program or employer. Some groups have email addresses you're supposed to send a form into that you would obtain from your human resources department.
You should probably talk to your IT or Cell phone guys at your company, if its from your company then *611 won't able to help much
If you're at Loblaws/Superstore/Zehrs etc. you need to speak with Mobile Shop staff and they can send out the form for you. If your store doesn't have one, I can see if I can get it to you since I used to work for them. As for Wal Mart, the Wal Mart electronics or mobile staff should be able to get that for you.
Hi,You will need a Employee Purchase Plan:Enrloment Form signed by your Department Manager ,You can get one of these forms from yr phone people in the connection center.
