Need to be able to put account on Hold at a reduced cost WITHOUT loosing plan.
  • 22 October 2013
  • 28 replies
  • 306 views
I Travel for work and am out of the Country, usually overseas, for a month or more at a time for roughly half the year. Some of my other colleagues with other carriers (Canada, USA, Europe) are able to put their account on HOLD while they are away for extended periods of time. These carriers either reduce their plan to $0 or a nominal fee $10-15 for a specified duration. And when they re-enable their account, they have the SAME plan they had when they left. Koodo needs to implement the same thing. I'm paying $60+tax for services I don't even touch while I'm away but need my current plan options while I'm home. I would be happy paying $10-$15/mth while I'm away to keep background services like voicemail and call forwarding active if I could return to my previous plan upon my return. Obviously, this service could be limited to a certain number of consecutive days and total days/months per year. Thanks.
Seasonal Hold is available for $15/month (max 6 months), but you mentioned keeping your plan, which is not the case here as it will be considered a plan change if you opt for it. Koodo is the only carrier that does it this way and you bring up a good idea of modifying it so it doesn't affect your plan. Something to consider.
Seasonal Hold is available for $15/month (max 6 months), but you mentioned keeping your plan, whi...Is there any latest update on this suggestion as it is now 3 years old?
Seasonal Hold is available for $15/month (max 6 months), but you mentioned keeping your plan, whi...The process is still the same. Switching to the Seasonal Hold keeps your number, but not your plan.
Maybe since they are loosing revenue and tab contributions during this time they could do it only for users who's tab balance is within 30% of being paid off. Or have clear tabs.
It's been brought up before and I wholeheartedly agree with you: the seasonal hold should put the [b]plan on hold...not just the number!
Userlevel 3
It's been brought up before and I wholeheartedly agree with you: the seasonal hold should put the...Other than keeping your number what is the point of seasonal hold? I guess you don't have to pay off your tab but at $15/month maybe just pay off the tab and hope for a.gift card promo when you want to return?
It's been brought up before and I wholeheartedly agree with you: the seasonal hold should put the...Really Moonmack, personally I see no use at all the way it is now, except to keep your Tab flowing...
But for people who brought their own device and are "Tab free", it would be much cheaper to port out the number to for example Speakout ($25 for a whole year) or VOIP (free, but not possible for every number) and then come back to Koodo a few months later with a new account and port the number back in.
It's been brought up before and I wholeheartedly agree with you: the seasonal hold should put the...Keeping my Plan is concern #1 for me! I need my 6GB plan when I'm home. Number is important as well... and it would just be easier to call Koodo or go to self serve and pay a few bucks per month than to deal with porting back and forth and picking new plans all the time.
Userlevel 2
Here's me question to everyone How would you program it into the system to make it work like you want it to?
Here's me question to everyone How would you program it into the system to make it work like y...Myke, with a due respect, we are customers and really it wouldn't be up.to the customer to figure out how to program it into the back end. That's for Koodo to figure out if it's feasible and if so, how to program it. Anything is possible, haven't you ever seen a Disney movie?
Userlevel 2
Here's me question to everyone How would you program it into the system to make it work like y...Let's not mix fantasy with reality here 😉. Let's be honest here. If there was a better way of doing it, Koodo would of figured it out by now(I reference the fixed data amount addons not being compatable with the data saver tier structuring issue). And really, all seasonal hold is, is a discounted rate to keep the account active while not paying full price for your normal rate plan. I can appreciate wanting another way for it to happen, constantly asking for it without providing examples isn't really going to get anyone anywhere.
Here's me question to everyone How would you program it into the system to make it work like y...For a simple but crude option: Same as they do now with the Seasonal plan but they would note the plan and rates at the time of the switch. Seasonal plan could easily be adjusted to include voicemail and/or call forwarding. Like Chad said, that's for Koodo to figure out.
Userlevel 2
Here's me question to everyone How would you program it into the system to make it work like y...Except that if the plan isn't available at the time of switching back, a new plan must be selected. You cannot obtain a plan that isn't currently available.
Userlevel 3
Here's me question to everyone How would you program it into the system to make it work like y...Could you keep the same plan and fee but cut services and provide a rebate. So if I pay $50 a month for my plan there would be no change for a seasonal hold but I would add data and voice turned off for a -$35 fee. So $50-$35 is the $15 seasonal fee but you don't tell the computer the plan has changed. I think this idea is a crude hack but is it likely to work? It would require an add-on that has a negative rate and effectively prevents the service from working.
Here's me question to everyone How would you program it into the system to make it work like y...Yes you can... I've done it. It took a lot of time on the phone with various tiers of managers, but anything is possible. Either way, the people at Koodo I'm sure would figure out a more streamlined way to make it happen if there was enough demand for it.
So let's say it can't be done for the current plans, fine. Can't the new plans be reprogrammed with an internal suspend switch? not knowing how the back end works or how to program outside visual Basic puts me at a disadvantage.
Userlevel 2
So let's say it can't be done for the current plans, fine. Can't the new plans be reprogrammed...Well all accounts can be suspended. Not sure what you're meaning here.
So let's say it can't be done for the current plans, fine. Can't the new plans be reprogrammed...As in the plan is still in place but marked as suspended. So suspend would no longer need to be a rate plan change
Userlevel 2
So let's say it can't be done for the current plans, fine. Can't the new plans be reprogrammed...Well yeah, you can always do that, but you have to pay price of the rate plan even with the account suspended.
So let's say it can't be done for the current plans, fine. Can't the new plans be reprogrammed...Yes now, but if a modification could be made to add a price change for the plan instead of a change of plan
Userlevel 2
So let's say it can't be done for the current plans, fine. Can't the new plans be reprogrammed...I really don't think that 'implementation' is the problem here (ie: the billing system). Koodo is part of a multi-billion dollar telecommunications conglomerate with a vast array of extremely intelligent engineers and accountants on hand. Surely they are more then capable of ensuring their 'billing system' functions exactly as desired. I think the reason this hasn't been implemented is that 1) Koodo doesn't see it as a priority, or 2) the current system functions exactly as they desire it to, which includes migrating customers on grandfathered plans to inmarket plans upon return.
So let's say it can't be done for the current plans, fine. Can't the new plans be reprogrammed...^ star, mattjs 🙂
So let's say it can't be done for the current plans, fine. Can't the new plans be reprogrammed...Agree
So let's say it can't be done for the current plans, fine. Can't the new plans be reprogrammed...I think you hit the nail in the face there Matt. I just think they should change their model a bit or at least start keeping new plans a little more in line with the old plans. They are essentially blocking me from migrating because they don't have a 'new' 6GB plan, thereby blocking me from taking advantage of their current seasonal plan.
So let's say it can't be done for the current plans, fine. Can't the new plans be reprogrammed...Completely agree with Mattjs, wow did I just say that haha 😉 If this idea is implemented then it should only be available for ppl without a negative tab balance as it would confuse the 24 month rule and ppl would take advantage of it.
