Need help setting up MMS on a Nokia Asha 302
Does anyone know how to set up MMS messaging on a Nokia Asha 302? I managed to get the Internet is working over the data connection but can't seem to get the MMS to work (incoming or outgoing). Anyone have any tips?
Look under text m3ssaging settings for mms configurations. Configuring unlocked feature phones is always a bit hit and miss since the required settings are usually distributed between 3 or 4 different menus.
I had trouble logging back in so forgive my photo answer but..
I followed your instructions to the letter and it still doesn't work 😞 That was my issue before as well. I had tried all those in even before but I thought I was doing something wrong. I checked the SIM card in a different phone and it works so it's definitely the phone setup. The WIFI is not on either. I'm running out of ideas.
