Need Help
Hi, i am wanting to get on the Koodo tab, but i would like to know what age i need to be to get on it before i go to the koodo store. thanks 🙂
Hello! You need to be the age of majority in whichever province/territory you reside in.
I Live in Ontario, i have looked all over google, and i can't seem to find what age i need to be to get on the koodo tab
If you google "age of majority Canada" it will tell you. For instance this was the first return:
http://www.justice.gc.ca/eng/rp-pr/fl-lf/famil/cons/consdoc/cscam-paem.html
Thank you very much for the help, i appreciate it 🙂
Its 18 in ontario. Its when your eligible for credit.
Glad to help!
What may be equally important: to go on the Tab you need certain ID and must pass a credit check.
http://help.koodomobile.com/getting-started-with-koodo/before-you-purchase/do-you-perform-a-credit-c...
For pre-paid, all you really need is an unlocked or Koodo/Telus family phone + the appropriate pre-paid SIM with some payment vouchers and a valid email + billing address. No credit check required.
Good luck.
