My Phone says Mobile not avilabel Not Kool!!
My Phone aint workin and im starteing to freak! It says mobile not availebl and i tried to get off the airplane mode and take off the battery still Nothing HELP
Make sure you have 3g enabled and it is not set to 2g only. 🙂
did that....ahhhh im sad
by accicedent i asked for the Roger netwaork but im with Kodoo can this make it worse i was tryin ait all
plus Ive been realizing that my battery dies pretty quick eventhough i charged it all nite wtf
Set the network back to automatic, that should do it 🙂
wow still nothing but thanx foe trying peeps.No Hope
When did you get your phone? Was it working before?
Could you tell us what phone you have? (model name or make e.g. Samsung Galaxy Ace 2x, S2x, etc.) Are you on prepaid or do you have a monthly rate plan? We'll need this info so we can troubleshoot further.
Make sure that you are not in airplane or flight mode - you said that you tried to but not if it actually turned off - usually there is a pic of an airplane at the top of the screen if it is still on. Same as 3G mode but another way of saying it (GSM/HSPA (Auto mode)) Also, if your phone is losing battery life quicker than normal - do u have ios 7 installed on an iphone 4 or 4s - found that this upgrade can kill a battery quicker than normal
Userlevel 2
Hey Victoria! If you have a chance, please visit a Koodo store : http://koo.do/IX6h7U They’ll be able to assist you further. Thanks. ________________________ If you see a good answer, give it a star.
If it is an iphone, i found that turning off background app refresh saves a lot of battery .
