lost without a cell phone!!
ok so id really like a cell phone on a plan i was with rogers a few years ago and i have bad credit now because of them i had cancelled my contract with them and they kept billing me 6 months afterward and now say i owe i think around 1000 dollars ive also benn on prepais and i really didnt like it i wouldnt mind being on what i understand is spending limit program but is my situation with rogers going to stop me from being a costomer with koodo????????
It really depends, You'll have to go through a credit check with koodo http://help.koodomobile.com/getting-started-with-koodo/before-you-purchase/do-you-perform-a-credit-check and they will determine if you're eligible for a regular monthly plan or the spending limit program, otherwise there is the option of prepaid which requires no credit check. Koodo prepaid is actually quite good since the boosters never expire until they are all used up! (as long as the account is renewed at least every 90 days) Ugh I'm not a fan of rogers, hope you get everything solved! Wish you the best!
no one in here can tell you if your bad credit is good enough to be on the spending limit program you just have to apply and see what happens as daniel said prepaid with koodo is actually pretty awesome compared to the regular monthly plans these days i would advise taking a serious look at prepaid before you really decide on a monthly plan
