Lost mms send and receive
  • 22 November 2021
  • 8 replies
  • 121 views
I updated my plan that has been working flawlessly from 5G to 10G per month and now I can no longer send or receive mms. Android Xiaomi Mi9T
Data still working
Best answer by Dinh 22 November 2021, 05:50
Can you check if your APN was set correctly as per this https://www.koodomobile.com/en/help/setting-data-your-non-koodo-phone
Also, If possible, can you post the APN setting of your phone here?(hide/delete all personal information before posting pls)
This is what I have
Name-Koodo
APN- sp.koodo.ca
MMSC- http://aliasredirect.net/proxy/koodo/mmsc
MMS proxy-74.49.0.18
MMS port-80
MCC-302
MNC-220
APN type default,supl,mms
APN-roaming protocal-IPv4/IPv6
APN-enabled
Tried adding a new APN with instructions and lost all data
Name-Koodo
APN- sp.koodo.ca
MMS proxy-mmscproxy.mobility.ca
MMS port-8799
MCC-302
MNC-220
APN-enabled
It is veryhard to check what is wrong and right from the typing. Could you post a snapshot of the apn you had in the phone ?
There are 2 wrong parameters there.
MMS Proxy:  mmscproxy.mobility.ca
MMS port: 8799
Also make sure
APN protocol is set to IPv4
APN roaming Protocol IPv4
I suggest you change them and see if that work
That did the trick!, Thank you
