Is there a roaming charge for using "Map and Go" in the USA?
Roaming charges for navigating in the US
If it uses minutes or text or data then yes it will. If you can use it offline in airplane more with only GPS on then no it won't
If you are using data in order to use it then yes. If the maps are saved onto your device then no.
