International roaming question
I am travelling to India. Presently I have 50 cad plan.
Will I be changed for incoming messages on my koodo number if I am in India?
i just want to use my koodo number for receiving messages
Any suggestions?
Receiving messages is free.
But if you reply to it, then there will be charge.
Any suggestions?
As @Mayumi said, there is no cost for receiving text messages while abroad. However, you should be cautious of your usage. In many cases, there may be data leakage from your phone, which may trigger the Easy Roam feature.
Note that charges for Easy Roam are based on the number of days you use your monthly plan’s minutes, data or texts while abroad. The service costs $13 per day and is capped at $150 per billing cycle.
It’s highly recommended that you put your phone on airplane mode and only turn it off when you actually need to use your service.
Thanks, i am planning to purchase a cheap plan for sometime on Koodo, it will be useful for the next few months
