International roaming problem
  • 9 April 2014
  • 2 replies
  • 13 views
I added an international roaming package but am unable to use it to log onto the internet. Is there something I need to do or enable on the phone?
It's possible that your data roaming is set to be off on your phone. Check under settings.
Did you also add the International Data Roaming too? http://help.koodomobile.com/coverage-long-distance-and-travelling/Travelling
