Feedback
incoming calls from US | Koodo Community
  • 29 December 2020
  • 1 reply
  • 116 views
I have a friend that lives in the USA I know that if I make a call to her I will get charged the 60 cents but if she calls me (incoming call) will I still be charged?
Best answer by Allan M 29 December 2020, 16:34
Nope! Incoming calls are alright, you won't receive any extra charges.
(They will use your minutes though so if you have a plan with x amount of minutes and go over that then you'll obviously have extra charges. If your plan has unlimited then you don't have to worry.)
1 reply
