I put a password on my computer and now when I punch it in it says it's incorrect and I'm going on 50 times wrong. Someone please help
I can't get into my phone keeps saying the password is wrong and it's going on 52 times and I still can't get inti my phone
What kind pf phone do you have? You said you put a password on your comouter and now your phone is locked? Could you explain?
Allan wrote:
What kind pf phone do you have? You said you put a password on your comouter and now your phone i...
Help me please
I have an lg phone and I meant password on my phone not my computer. I can receive calls but can't call out. Could someone please call me at xxx-xxx-xxxx please I need to access my phone
I have an lg 4 I think. I put the password on my phone and now it won't let me in, keeps saying it's the wrong password. I can't call anyone cause it's for emergency's only but ppl can call me please someone call me at xxxxxxxxxx
Try my method below. As well, this is a public forum so I would refrain from leaving your number on here.
I have an LG I put the password on my phohe so no one could get into it I've pushed the password 53 times now and it won't let me unlock it. I need my phone
Do you have device manager set up? If so try this:
On a computer or other mobile phone, visit: https://google.com/android/devicemanager
Sign in using your Google login details that you also used on your locked phone.
Select the device you need to unlock (if it isn’t already selected).
Select ‘Lock’
In the appearing window, enter a temporary password. You don’t have to enter a recovery message. Now click ‘Lock’ again.
If it was successful, you should see a confirmation below the box with the buttons Ring, Lock and Erase.
On your phone you should now see a password field in which you should enter the temporary password. This should unlock your phone.
Go to your phone’s lock screen settings and disable the temporary password.
