I need the PUK code
  • 21 September 2013
  • 255 views
I am travelling in Europe for the next couple of weeks. I have purchased a local SIM card but need the PUK code to unlock the SIM of the old card. Can you please provide the code.
You'll need to contact Koodo for your PUK code, Jennifer, they can provide you with that. You can either send them an email, or call their international number: http://koodomobile.com/en/bc/contact.shtml Are you sure though it's the PUK you need? Normally that is only needed when you enter your PIN code wrong a number of times, to unlock the SIM card itself. I'm unclear what your European SIM has to do with that, but perhaps I misunderstood 🙂 If it's unlocking the phone you're after, you won't need a PUK code... you'll need an unlock code for your phone from either Koodo ($50) or a third party unlocking service.
You'll need to contact Koodo for your PUK code, Jennifer, they can provide you with that. You can...If it's an unlock code you need check out GSM Liberty. Com or cellunlocker
Userlevel 4
To remove network restriction you just need unlock code..you can get that from http://www.onlineg...Thanks for coming out! However, we have all the spam we need.
