i'm unable to make long distance calls it say call cancelled.
1 reply
Only LD calls but local still works? That's odd. No matter if it's LD or not, a failed call is a failed call. Are you putting a 1 in front of the #? Try putting your phone in airplane mode for a minute and then turn it off again. If that fails, remove the battery (if possible) and SIM card for a minute and try again.
