I have no connection on my unlocked LG G3.
Cant connect to network with my LG G3. I can call/text no problem.
Can you check please if these settings are correct on your phone? http://help.koodomobile.com/plans-add-ons-data-and-other-services/data/how-do-i-setup-data-on-my-non-koodo-phone
Sophia wrote:
Can you check please if these settings are correct on your phone? http://help.koodomobile.com/pla...
Link doesn't work anymore 😞
Worked for me.
Hey David, have you tried Sophia's suggestion? Keep us posted!
********************************************  If you see a good answer, give it a star.
Hi, the link to Android seems to broken on that thread. Can you please get it fixed and confirm?
