I have 74 minutes left to make calls in Canada but I am not able why?
I don't know, Monika. We need more information for sure, do you have service on your phone? What phone is it? What plan are you on? What errors are you getting?
Its most likely that your base plan has expired. If you dial *611 it will let you know right away if its expired. Try pulling out the battery if your base plan is active. if that doesn't work call customer service *611 and explain to them what's going on and they will help you out 🙂
I bought last month prepay koodo for 15 dollars and I should have free messages, two weeks ago I top up for 10 dollars and 2 days ago I top up for 20 dollars when I check my booster they say that I have 74 minutes left when I try ring it tell me I need contact with 611 but when I choose option 6 automatically put me down
it seems like the base plan did not activate. Try calling customer service. *611 keep hitting 0 til you get to a rep 😃
Thank you you help me I am very appreciate 🙂
They said that I need top up for 15 dollars my basis plan expire today I am not sure about free text messages can I still send?
if the base plan is expired no. whats your current balance when you call *611?
it is 0 dollars I need top up my mistake I thought if I will buy 20 dollars and buy booster this will extend my plan. If the base plan expired this means that no one can't send to me message as well?
exactly Monica! once you get the $15 top up voucher you will be able to start sending and receiving messages and phone calls 🙂
