how will my data usage be affected by the new voicemail system
simple question - how will my data usage be affected by the new voicemail system. will the downloading of those .wav files become part of my data usage or ...? can anyone answer this please?
If you download your old vm messages as wav files using your cellular data connection, then yes, it will count against your data usage. This only applies to downloading saved messages from the old system. Checking your vm on the new system works exactly the same way as the old one used to. No data required, although you will still use minutes to check it.
@ Tony the recommended method is via downloading via PC. If not, wi-fi to avoid chargeable data usage.
http://help.koodomobile.com/voicemail/Koodos-New-Voicemail-System/Can-I-permanently-save-voicemails-...
so - I need to go home, check my pc in order to retrieve my phone messages - why would I want to stay with Koodo
tony wrote:
so - I need to go home, check my pc in order to retrieve my phone messages - why would I want to ...
No. The only way that downloading wav files will be involved in any way is if you have old voicemail messages saved on the old system. If you wish to keep these messages they need to be converted to wav files and you need to download them before the old system is shut down entirely. As far as day to day use of voicemail ABSOLUTELY NOTHING IS CHANGING. You will still dial into voicemail and check your messages exactly the same way you do now.
