How to tell if my nexus s is unlocked ?
Best answer by Moonmack 19 September 2013, 13:31
All Nexus S phones were sold carrier unlocked. So you can put any carrier's SIM in without needing an unlock code. It is a quad band so you can only use carriers with matching frequencies. So a Nexus S from Koodo won't work with Wind even though it is unlocked. Maybe you meant something else like rooted? The Nexus is easy enough to root but doesn't come that way. This is needed if you want to load your own O.S. on the phone.
1 reply
Userlevel 3
