How to restrict roaming while not shutting off your data when travelling between the US and CAN
  • 10 May 2019
  • 7 replies
  • 293 views
I current work on a vessel in the pacific and often use data when I have service, However, my close proximity to the US means that every now and then it goes through a US network without my knowledge.
Is there a way to leave my data on so that i can see and use it when im in koodo service range while not using data when I am no longer in range and instead piggyback through a US network?
Best answer by Dennis 10 May 2019, 23:37
You can turn data roaming off So data won't roam but you can still receive texts and calls if you are international. And if you are on a Canadian network it will use data like normal
If data is on then data will be used when a connection is made.
Could you not turn data off and just look and how many signal bars you have?
Thats true, however I want to utilize my data without accidentally going through a US network. I received an alert that i had done as such only a couple of days ago. I was completely unaware that I was roaming at the time and wish to prevent a re-occurrence of that.
Where am I able to select that? Online with koodo selfserve or on my own phone? I couldnt seem to find that option
On your phone.
Go to Settings>Connections>Mobile Networks
Or something similar. It could be under Settings Data.
The only phones I've ever seen where data roaming was enabled by default were Blackberry devices.
If you want to disable all chargeable roaming: on your handset, look up providers In network preferences and deselect automatic. Do a manual search and choose Koodo as your sole provider.
You should now have service only when connected to a domestic Koodo tower. If Koodo does not show up in the options after your handset has done a scan, you can also choose Bell since they share infrastructure.
