How to order a replacement battery
Hello, Need to replace a battery, no warranty, will pay but cannot get an acceptable answer from KODO as to how to order the darn thing.Would appreciate it it someone has had this issue and can provide the answer.
Try going to best buy or future shop if it's a popular high end Samsung device or check EBay
If you tell us EXACTLY which phone you have, meaning the make and model we may be able to direct in a more specific direction towards what you're looking for
