How To Adjust Rings Before Voicemail
  • 25 October 2020
  • 2 replies
  • 55 views
Just signed up with Koodo mobile. Can anyone tell me how to adjust the number of rings or time before voicemail kicks in. All I could find was to contact Koodo’s tech department, which I can’t find a way to do.
Thanks a lot.
See link for android ring settings https://www.wikihow.com/Change-Number-of-Rings-on-Android
  1. Dial *#61# and record your voicemail phone number
  2. Dial the service code. The code should be entered in this format **61*voicemailphonenumber**seconds#
  3. You can enter delay of 5 /10/15/20/25/30 seconds
Try this
https://www.reddit.com/r/Koodo/comments/9wq4e4/how_to_change_number_of_rings_before_voicemail/e9mqrkt/
