how do u switch all ur data that saves on ur phone to save to ur SD card ???
well i have a Samsung galaxy and all my stuff keeps saving to my phone and not my SD card and I don't know how to put it so from now on stuff gose on my SD card not my phones storage
Best answer by Paul Deschamps 26 November 2013, 22:41
You can only save pictures and videos to the SD Card not games or apps. To change saving pictures from internal Storage to your SD Card go into your camera app and then enter the ssettings within the app and at the bottom there will be an option to save to SD Card or internal, just choose SD Card and there you go. You can use a file Explorer app Like "PowerGrasp" to move certain files to the SD Card that are already on you device.
1 reply
