How do I return a sim card?
I ordered and received it but need to return it – pretty sure I have 2 weeks?
Best answer by Mayumi 9 November 2018, 01:00
I don't think so neither.
I was told by store rep that I can't return SIM card. It was long time ago before they sell tricut SIM (I forgot it's micro or nano).
But I believe that chances are same.
Basically the same way you got it. In store? Go to store. Online? Contact the webstore.
https://www.koodomobile.com/help/returning-or-exchanging-your-koodo-phone
I don't actually think you can return sim cards. They're one time use and there's no way to tell from a visual inspection whether they've been activated or not.
Post paid sim cards are free
...and here's the final confirmation, from koodo's webstore page:
Just save the Sim card for future use. If you don't activate it it will be fine to use at a later date
