How do I check my past incoming and outgoing calls?
Best answer by John Lee 9 August 2013, 03:39
You can check your previous incoming and outgoing calls on Koodo Self Serve by clicking the Billing option, then your e-bill and then there should be another option that says "Previous Usage" and you can click the airtime usage and see your past incoming and outgoing calls.
1 reply
