Home phone
Does koodo have the cellular home phone? If koodo isn't going to do the same as fido and rogers I might pay $30 for their home phone! Still cheaper then bell land line, but would be really cool if koodo follows suit.
Best answer by Chad Burr 31 January 2015, 16:13
While koodo doesn't offer home phone service, you can save tons just by buying some new phones.
Look around at Walmart and Future shop for cordless Bluetooth home phones. These devices connect with your cell when it's in range and turns the cordless phones into extensions of your cell.
Make sure your plan is sufficient for the calls you think you'll be making.
Most of these phones can be found starting at 59$ or more. Compare that with paying fido an extra 30$ per month.
Here's an example of the device I'm talking about
http://www.vtechphones.com/learn/more...
1 reply
