Hi I am just wondering if they know when we will be able to get smart phones in Northern Ontario.....currently using a CDMA phone still
Userlevel 2
You can get smartphones now as there's HSPA service in Northern Ontario.
really! Thats Great!!!! Thanks so much
Check out the coverage map. Make sure you use the drop down to select CDMA or 4G to compare the network types depending where you are in Northern Ontario http://help.koodomobile.com/coverage-long-distance-and-travelling/coverage-maps
Userlevel 2
There's some spots along the highway where there still is no HSPA coverage.
In Thunder Bay, at least.
