Dialing a "Pause" Problem
From Contatcs list, "Pause" (coma) followed by numeric password for voice mail do not transmit after voice mail phone number is dialed. All works fine if I manually dial. Any advise?
Try putting in multiple comas. So for example, if 555-555-5555,xxxx isn't working, try 555-555-555,,XXXX
I've also heard that putting a # symbol at the end of the password sometimes makes it work... My phone is dead at the moment so I can't try to find out to be sure. But it would look like 555-555-5555,,XXXX#
It works fine for me when done from the contact list. What phone do you have?
i also have the same problem. My phone is the samsung s2. SGH T989D. I tried the double pause and the # but those do not work either.
Kevin Dancs wrote:
i also have the same problem. My phone is the samsung s2. SGH T989D. I tried the double pause...
I've got the same phone, so I figured I should actually try this out myself. So I just dialed my own number from the cell: 1-555-555-5555,,XXXX and it worked. Not sure why it's not working for you.
Aaron. Thanks for the reply. To clarify with a bit more detail. The pause and password work and I do get connected to the voicemail. The issue is that once connected the phone will not send any more prompts. I press "1" to listen to messages but the phone does not transmit the signal. Like Dayle above, all works fine when I remove pause and password from voicemail number.
So after it logs in using the 555-555-5555,,XXXX it won't register any dial tones after that, even when you manually press the number on the keypad? I'm trying to replicate the problem on my phone, but I'm not using stock software, and that could be the difference. Interestingly enough, 555-555-5555,,xxxx,,1 works to check new messages 🙂 I'll see if I can figure a way to make it not accept any input after the number is initially dialed.
I tried 555-555-5555,,xxxx,,1 When i tried to save the phone told me the change was unsuccessful. Too many digits? I removed one comma and the change was successful. 555-555-5555,,xxxx,1 . It played the one message I had but would not accept any further manual input.
See that's just weird. It's like your dmtf tones are getting disabled, but as far as I know there's no way to do that on the S2X. I'll keep looking.
Is there anybody else with a Stock SII X that Can try this out? I'd hate to think I'm going to have to flash back to stock just to give this a whirl
It doesn't work here either. Rooted but stock SII x...
crazy. So it's a stock issue. Well I'll be damned. Thanks for saving me from going back to stock! I was so cringing at the prospect... Maybe a 3rd party dialer might work? This one here seems to get good reviews: https://play.google.com/store/apps/details?id=kz.mek.DialerOne&feature=search_result#?t=W251bGwsMSwxLDEsImt6Lm1lay5EaWFsZXJPbmUiXQ.. Of course a person could always come over to the darkside of flashing and avoid this problem altogether 🙂 EDIT: I tried the app, it just boots up the stock dialer when it actually comes time to start dialing... disappointing
Ok, this really shouldn't matter, but for giggles make sure this is turned on. Also, when you press a number on the keypad, do you hear a tone?
Aaron MacIntyre wrote:
Ok, this really shouldn't matter, but for giggles make sure this is turned on. Also, when you...
If you want to press option 2 to send a message (to yourself) the screen displays the numbers pressed, but no DTMF tones can be heard even with audible touch tones enabled. An interesting find!
Indeed. I guess it's not a bug people would run into a lot. Now the rom I'm running now is 4.1.2 based, so potentially this is something that will be fixed in the upcoming update for the SII X, as it's getting a slice of JB. When that update comes is anybodies guess.
settings > sound dial pad touch tones (checked) Doesn't make a difference. i did notice that if you dial a number on the phone keypad I have audible touch tones. But the touch tones are not audible after the voicemail number has been dialed and I am prompted by the voicemail service. Even though the tones are not audible the phone must still be sending the signals as the voicemail works fine without the pause. It is only after I add the pause and password that the tones are not recognized.
Yeah see, when I'm using it on the rom I'm using (unofficial slimbean 3.1), even after it dials into the voice mail I can still hear the tones plain as day. When I turn the audible sounds off, I don't hear anything, but everything still works regardless of the method I use. I just wanted you to turn the audible tones on for giggles, in reality it shouldn't of fixed anything. I'm really leaning towards it might be a bug with the stock dialer on the SII X
mine is 4.0.4 Thanks for your help Aaron. I will just hope for the update soon.
Yeah I wish I could of been more help. As for the update... Depends on your definition of soon 😉 Could be waiting until the March/April area. If that seems like too long of a wait, there are a bunch of custom roms available SII X. If you're a little nervous about the whole thing, do some reading up on it. Good place to start is the xda forums for T-mobile SII T989/hercules (identical in every way to our SII 😵. http://forum.xda-developers.com/forumdisplay.php?f=1329 And here's a link of all the software and such I've used personally and can vouch for: http://www.jughound.com/t989.html And now for the disclaimer. You can potentially brick your phone if you don't follow the instructions in any given guide correctly. You technically void your warranty by installing custom roms, and samsung uses a "flash counter" to tell if you do. You can reset the flash counter if you ever want to return your phone for warranty service by using the instructions provided on the below link: http://forum.xda-developers.com/showthread.php?t=1578184 And yeah, to each their own.
Same problem here with S2X, workaround I found is after the automatic dial sequence put the call on hold then release from hold and tones are active again.
Laptop Farmer wrote:
Same problem here with S2X, workaround I found is after the automatic dial sequence put the call ...
Good stuff! So it's for sure a stock issue then. Interesting fix, thanks for sharing.
I also have the Samsung S2X. My problem is that the touch tones simply don't work... I don't hear anything when I try to access my voicemail... And yes, the settings "Dial pad touch tones" and "Touch sounds" are checked. I tried with or without speaker, nothing seems to work, any suggestion would be greatly appreciated... Can't listen to my messages at this stage... Thanks.
Xavier Barbot wrote:
I also have the Samsung S2X. My problem is that the touch tones simply don't work... I don't hear...
Try this... Settings > Sound > Volumes - check that the Speaker and System sliders are set to max position/volume. Then check, Settings > Sound - Silent mode - should be set to off. In your Notification windowshade (drag finger from top of screen downward), check that Sound mode is enabled (grey speaker with a diagonal line through it) and not Vibrate or Mute - tap icon to change modes.
You're the man... That fixed it, thanks a bunch! 🙂
