Feedback
Data vs WIFI | Koodo Community
Data vs WIFI
  • 15 September 2021
  • 1 reply
  • 20 views
When I am home or at work where there is Wifi, I seem to be using Data.
Why?
1 reply
If you have an iPhone or some android OEM's, there is a wifi assit option that will auto switch to data if your WiFi signal is too weak. You can shut that off and see if data is still being used
