I have more than enough data but 90% of the time when I try to connect to my data it won’t work.  I turn off connect to wifi when I'm out so it’s to connecting to that but can’t seem to get my data to work.  I’ve never even come close to using half my data.
What happens the other 10% of the time?
Are you noticing this in specific areas?
Does talk and text work when you cellular data is not working?
Do you check your data connection through trying various apps and webpages?
All of my apps are able to use cellular data and most times won’t connect or take awhile to connect. Siri is hit or miss if she’ll read my text messages while driving. I have even tried typing in a website instead of the app and it takes awhile to load or not at all. Usually happens when in stores. My iPhone is up to date, apps up to date. Most times I have to shut down my phone. My iPhone is an iPhone 11 so not too old.
