Anyone have any troubleshooting options for my data dropping every 5mins or so?
I have a OnePlus 7T on Koodo network. For some reason my data icon always shows 4-5 bars of service with 4G+ but it has a "!" point at the end. I know this means it's having troubles connecting to the network and my data gets interrupted. This happens a lot in Edmonton area but seemed fine using other towers. I didn't have any problems with the same phone until I switched my plan from 4Gs a month to 11Gs on promotion. I have played with the APNs to try to help, cycled the airplane mode, restarted the phone, and reset the network information. No luck.
Any help is appreciated.
Best answer by nim4165
See solution for a similar case at https://community.koodomobile.com/android-81490/oneplus-8-connectivity-issue-7800347
