Changing ringtones on Alcatel A392A flip phone
Can you change/download ringtones to Alcatel a392a phone? If yes How? The phone I have differs in several ways from the guide description including not having a ringtone folder.
Hello. I don't have the phone myself but try this :
1. open phone, and push the side key under the memory card slot.
2. scroll over to the 'PROFILE' setting
3. highlight the 'NORMAL' setting, and push the 'OPTIONS' key.
4. go to 'EDIT'. push 'CALL ALERT' and you get a wealth of options. you can also edit the MESSAGE and PHONE SOUNDS options.
Looking at this user guide (http://images.wirelessdealer.ca/images/phones/userguide3785.pdf), it looks like the option is indeed available
1. open phone, and push the side key u...
Got it. Done.  Thanks!
Glad I helped. Have a nice day
profile--> general --> customize brings up the menu for changes, including ringtone type and volume etc
Mine doesn't say anything about ringtone
This may be of help, Marjorie.
Looks like you have to go to: Settings > General > Options\Customize and select Ringtone by scrolling through the menu options with the phones' navigation key.
does not work would really like to change the ring tone
on the upper part of the right key it work perfectly thank you Robert
No problem. Have a nice day!
Recommended ringtones for music lovers:https://ringtonesmobile.net/shape-of-you-ringtone-download.html
