changing my phone and want to keep my actual plan
if i change my cellphone for an samsung galaxy s3 on the small plan and im actually on a small plan with a samsung galaxy ace 2x, can i keep my actual plan?
Yes, I assuming by small plan you mean small tab.
You only have to change your plan if you upgrade your tab level from small and your current plan is less than 30$ (or you're moving to tab large)
Otherwise you can continue using tab small and keep your plan.
okay, well I have a 59$ plan on a small tab and i want to change my phone but i'll stay on a small tab but can I keep my plan?
tikode357 wrote:
okay, well I have a 59$ plan on a small tab and i want to change my phone but i'll stay on a smal...
Yes
You could also switch to a Tab M and keep your plan. Even though there is a $5 monthly Tab M charge it saves you money over 2 years
ok
