Cell phone battery,
Can you buy a new phone battery at the Koodo stands you find in malls? I live in sherbrooke and want to know if I can go and buy a new phone battery at the mall where there is a Koodo stand
Hello Lila. I don't think Koodo has batteries in their kiosk. You should give them a call. Also, you could search the internet for one.
Just buy them online form amazon.ca. Prices are really good.
If you have an iPhone then you will have to go to Apple and get it replaced there since the battery is not removable. If it is another device that has a removable battery, some technology based stores may sell them or you could always look online at ebay, amazon, etc.
Hey Lila, your best bet is to give a call to our customer Service (*611 from a Koodo phone or 1-866-995-6636 from a landline), if your phone is still covered by the manufacturer's warranty (http://koo.do/JVO5Mk) we will ship a replacment battery at no cost 🙂 If you see a good answer, give it a star.
Userlevel 3
Often there is a shop that will custom build batteries for a reasonable price. I would suggest looking into Battery World in Alberta or Battery Boys in Saskatchewan. Anyone know something closer to Sherbrooke? I had bought an extra battery for my phone before they discontinued them, but in retrospect I should have just had it custom made when I needed it. Just make sure you hang onto the old battery - they may need to form factor. As mentioned already an iPhone battery is not easily replaceable,
