can u upgrade and keep the same plan
  • 22 February 2023
  • 2 replies
  • 52 views
Can u upgrade your phone and keep your same plan that u have ?
It depends, you actually can check it yourself by testing to do an upgrade in Selfserve there.
This table may help if you are upgrading on a tab
https://www.koodomobile.com/en/help/Keeping-or-changing-your-plan-when-you-upgrade-your-phone
