I am in my home office. I have a signal booster connected to a MIMO antennas. I am able to send text messages and I am able to access data network. In fact the download speed is as high as I have ever seen it.
However, I am unbale to make outgoing calls. The phone appears to be trying to call out, but no sounds are returned and after about 30 seconds the phone disconnects and displays “Call ended”.
I am unable to check my voicemail messages. I have also asked someone to call my number and they reported to me that the call did not even ring or revert to Voicemail.
I have powered off the phone, removed the SIM card and rebooted the phone. I even tried inserting an unused Telus SIM, restarted the phone, and tried tests again with no luck.
Using Network Cell Info Lite app I ma seeing the following….
TAC-ECI: 55506-139325769
eNM-LCID: Rotates thru 544241-73, 544241-43, and
RSRP: -94dBm
RSSNR = Ranges from 1.6dB to 6.4dB
RSRQ: -8
PCI: 211
NID: 70-1
Band: 2
My phone is indicating 3 bars and connected to LTE network.
I am also connected to the Bell network via a ZTE TurboHub to access the internet through the same MIMO antenna.
