can i take my sim card from my old rogers phone and put it in a koodoo phone so i don't lose my phone number and contacts??
tired of rogers, want to switch companies
Unfortunately you can't use a SIM card on any other network other than the one from which it was originally purchased. However, you can unlock you Rogers phone and use it on Koodo (assuming it's not GSM only) and you can port your Rogers number to Koodo if it's still active.
No you can't do it this way, but there's another way : http://help.koodomobile.com/getting-started-with-koodo/moving-your-number-to-koodo-new/how-do-i-move-my-number-to-koodo
If you want to use your Rogers sim card on your Koodo phone means,your phone must be unlocked one.If it's locked means,you will need to unlock it.For unlocking you can approach your service provider or else try to buy an unlocking service from any one of the online unlocking service provider like http://www.unlocking4u.com/supported-phones/rs6wp7/
