Can I switch phones but keep my plan??
I want to change from my blackberry 9300 to an iPhone 4. I just don't know if I can keep my plan. I pay $25 per month for 50 minuets and unlimited texting. Can I keep my plan?
to upgrad to newer phone and in order to benefit from new Medium/Large Tabs you should select a minimum of $30 Plan from new Koodo Plans it's compulsory, you cannot keep your $25 old plan and get new Tab.
MatB wrote:
to upgrad to newer phone and in order to benefit from new Medium/Large Tabs you should select a m...
Hi Mat, pleqase make sure to provide a complete answer. AJ can keep his plan if he goes for the Tab S. This is an important information. Thank you.
If you use the Tab S you can keep your $25 plan
Hi AJ, Denis is right! You can keep your current plan if you upgrade using the Tab S. Enjoy your new phone! ________________________ If you see a good answer, give it a star.
