Calls going to voicemail
  • 15 September 2020
  • 115 views
Phone not ringing. Calls going to voicemail. All settings checked and battery restart done. Switched SIM card to another phone and same problem. Suspect SIM card is the issue. Can I reprogram a SIM card from home?
Did it work before? What plan are you on?
Worked until today. On a monthly plan not pre-paid
Is it possible that  ‘call forwarding’ to your voicemail is enabled?
To disable an unconditional  ‘call forwarding’, if required and applicable to this case,  dial #21# and press Send. See https://www.koodomobile.com/en/help/call-forwarding
How about text and outgoing call? Can you text?
If you are a postpaid customer, I would suggest you check your selfserve and see if the account is in good condition and there was no overdue amount in the account.
