Calls going straight to voice mail
  • 22 October 2020
  • 65 views
Lately incoming calls go straight to voice mail with no missed calls. This has been happening quite frequently now. What is going on?
Has it been multiple numbers at random, or only select numbers?
It’s multiple numbers for sure. The most annoying one is when it ignores call from my condo buzzer.
Do you typically have good reception? Does this happen only in certain locations or everywhere?
Do you have Do Not Disturb mode on?
What happens when you try to call your line from another phone?
Check rejected numbers  if they are set with the option “Do out route to voicemail”.
Also check if they are not on the ‘blocked numbers’ list or that ‘Block unknown numbers’  option is enabled
